Configure a Peer Description
Configure a peer description to add descriptive text to an MSDP peer for easy identification of a peer.
  1. Enter either Global Configuration mode or VRF Router Configuration mode for a specific VRF context:
    enable
    configure terminal
    Optional: router vrf WORD<1-16>
  2. Configure the peer description:
    ip msdp description {A.B.C.D} WORD<1-255>
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp peer 21.0.0.2 primary
Variable definitions
The following table defines parameters for the ip msdp description command.
Variable
Value
{A.B.C.D}
Specifies the MSDP peer IP address.
WORD<1-255>
Specifies a descriptive text to a MSDP peer in the range of 1-255 characters. To include spaces in the peer description, enclose the text string in quotation marks.
